The_McClearys
Sep 25, 2019Explorer
If you want to walk on the patch, Clean the area, Smooth out or scrape off the Sealant over the damaged area. Glue a piece of 18 guage steel over the damaged area. The metal patch should extend at least 6 inches beyond the damaged area.
The Roof Repair Kits sold by Dicor or Super Flex have large sized patches of rubber roof material(TPO or EPDM). Cover the metal patch with a piece of the Rubber Roofing of the type you have and glue the rubber roof patch down using the glue provided in the patch kit.
Go around the edges of the patch with Eterna Bond Roof Sealant Tape, and then go around the edges and corners of the Eterna Bond with Dicor or Super Flex to keep it from coming loose.
The 18 guage steel will support your weight if you step on it.
44,070 PostsLatest Activity: Jul 01, 2022
