zulu52
Apr 10, 2018Explorer
Hellwig Bigwigs
I finally decided to make the upgrade to see if I can remedy the sway issue I have when the camper is loaded. I ordered the Hellwig Bigwig anti-sway bar for the rear of my 2015 Chevy 2500HD, 4X4, l...
zulu52 wrote:lakeside013104 wrote:
Installed my Hellwig bar myself in about 1.5 hours. I am only a basic (easy stuff) kind of mechanic, so if you have the tools and can read the general directions you should be fine.
Your picture looks a little low in the rear. My F350 looked the same until I installed Firestone air bags.
Between the bags and the Hellwig, the sag and sway issues have been reduced to where the ride feels smooth, with minimal sway and the truck sits level with only 28# of air in the bags.
Good luck and keep us posted.
Lakeside
I am hoping this helps the sway issue but if it needs more help wouldn't the next step be Stable Loads instead of airbags?
Do you need an on board air compressor for air bags? I'm not real familiar with them.
Zulu
