zulu52ExplorerApr 10, 2018Hellwig BigwigsI finally decided to make the upgrade to see if I can remedy the sway issue I have when the camper is loaded. I ordered the Hellwig Bigwig anti-sway bar for the rear of my 2015 Chevy 2500HD, 4X4, l...Show More
stevenalNomad IIIMay 14, 2018Looks a bit low from here. Can't you spin those u-bolts around the axle a bit to get better ground clearance?
Related ContentHellwig BigWig, Rancho's and suchBigwig disconnect?Roadmaster or HellwigHellwig sway barBigWig airbags
