btggraphix wrote:
What I am curious about is if that is still something you can easily change after the fact or if it would be a big PITA to change it later if you decided it needed to change and even change it around until you got it dialed in for your application.
I have a Bigwig and yes it adjustable, has 3 settings (holes) on the end of the bar. I do adjust mine, when the camper is on I have it set in the middle, when I pull the 5th wheel I set it to the inward hole. Takes about 10 minutes a side to unbolt the end and move it. It's been a great addition, takes a lot of side to side wobble out, when transitioning uneven surfaces
