btggraphix wrote:
Are the two brands using the same metal and treatment techniques? Is size the ONLY factor between them?
I doubt the metal is going to break on either and the stiffness of steel is the same regardless of alloy and temper. But on the ones I bought, the hardware and rubber pieces were nicer on the Roadmaster, and the Hellwig had a cheesy hammertone paint finish while the Roadmaster was cad plated.
Boatycall wrote:
HMS Beagle wrote:
I put a Roadmaster on the back of my '99 F350 2WD and a Hellwig on the front because Roadmaster did not make a front bar.
I wonder if that's just a 2wd/4wd thing, because other than that, we have the same truck and I have a Roadmaster in the front.
Exactly - no Roadmaster front bar for the 2WD truck.
