westend
Jul 07, 2015Explorer
I'd suggest to pull the edge trim on that front corner. If you do have some studs missing or damaged, you should see it by pulling that corner.
If you are mid-route, grab some butyl sealant like Mortite or the strip stuff and have that at the ready to reinstall the corner trim to complete your trip. If it turns out to be just loose staples, you can run a screw or two into a stud to keep the bubble flat. If that is the end of the project seal the trim edge with Proflex or Dicor. If not, the butyl will seal for awhile and allow for removal again when you get home.
44,056 PostsLatest Activity: Jan 19, 2026
