Dupa
Jan 20, 2023Explorer
3 tons wrote:
Regardless of the seemingly recent shelf date on your batteries or the voltage readout (at best, a marginal estimator of true battery condition…) using only the principle of Occam's Razor (from afar…) I’d say (from same issue past experience…) the root problem is that your batteries are near dead, yet ostensibly appearing satisfactory per voltage readout - Try as you might, wet-cells can act like this - this very situation is NOT unique or uncommon, and is a precursor to an internal cell or post connector failure.
The fact that the batteries ‘appear’ satisfactory yet are not (“say it ain’t so”!!) is from my perspective the true source of your dreaded frustration…JMHO
3 tons
This would certainly be the easiest solution, but I can't help thinking (perhaps because I'm a little out of my element on some of this) that if they were "near dead" this would/should somehow show up, at least a little bit, on either the load test or the specific gravity (both were fine)?
44,070 PostsLatest Activity: Aug 06, 2026
