greenno
Jan 21, 2023Explorer
OP not sure if your actually trying to get to the bottom of this but as I stated earlier in this thread find a good electrician and be done with it.
Do me a favor and pull the battery from your truck, assuming it's in good working order and fully charged.
Disconnect both your present camper batteries to isolate those out of the picture and connect up your truck battery to the camper.
If it does better than before then the camper battery's are not doing what there supposed to. Easy.
You dont need to use a drill for goodness sake. You have a nearly new camper. If it's been doing this since you've owned it .....
Isolate your systems and test them out.
If I had 1/2 hr at your camper I would tell you absolutely what the issue is.
Pretty easy to fix if you ask me.
Do what I suggested above and then post the results.
Guessing is just that guessing. Get some concrete answers and we'll get you squared away..
