Mountainrunner1's avatar
Jul 02, 2013
HELP !!!
Leaving tomorrow for a week and a half trip and I went to drain the black water tank and nothing would come out. It was recently de-winterized and we havent really used it except for my kids to go number 1. When I look down into the tank through the toilet there appears to be some kind of solid sludge which is why it probaby wont drain. Any ideas what this could be? I could take it back to the people who de-winterized it but every time they work on it there is something else that is wrong with it.
  • Could also be a stuck valve. You pull the lever and the door stays closed. Try the above first but if those remedies do not work. You may be looking at replacing the valve.
  • I think this is more than just toilet paper or left over residue. I can visibly see a thick sludge in the tank. I alway flush the toilet to add water to the tank before using it.
  • Good suggestions!
    You need to use allot more water never leave waste in the tank. Waste should be under liquid at all times. Never leave the dump valve open at a full hook up site. Only open to dump every few days as necessary.
  • Happened once to me, I think the last use left a wad of toilet tissue which washed to the exit gate and dried up to make a plug. I filled the black tank to about 1/2, dumped in 4 oz or more of PineSol, let it sit a few hours, then drove it around a bit and flushed. Everything came out fine.
  • Put twenty pounds of ice cubes and 5 gallons of water down the toilet. Then take the trailer for ride. Water and ice should break up what's in the tank.
44,068 PostsLatest Activity: Jun 17, 2026
