pianotuna
Aug 21, 2021Nomad III
riah wrote:
OK, thanks every one for your replies!
The biggest issue is voltage drop.
My 3 way fridge works GREAT on 12 volts--so long as I'm plugged into shore power. On batteries only--even though I have 556 amp-hours and 256 watts of solar it doesn't work well at all.
If you want to "fix" the problem, then add a dc to DC charger and set the voltage at 14.8.
