riah's avatar
riah
Help, 2003 Arctic Fox fridge isn’t staying cool when on DC
Quick question - has anyone had this issue with their refrigerator and if so, how can I resolve it?
We were hoping to run the RV fridge on DC electric while driving. We have 200 watts of solar panel and also had a dc/dc charger installed, with (2) 100 amp hr 12v LFA batteries in parallel (200 amp hrs 50% depth of discharge or 100 amp hrs without damaging the life span of the batteries) …
Before we left Thursday afternoon, we had it plugged in on AC the day prior and it was up to temperature when we left. On propane and AC it stays cold (40 degrees F or better) and the items in the freezer remain frozen solid. But, while the freezer seems to be working fine on DC, the temperature of the fridge seems to be running warmer (mid to upper 40s or worse) - I even put one of the frozen solid water bottles in the fridge on the middle shelf, as the temp began rising (which also started to thaw, not surprisingly since it was less than 0 degrees.) But the temp still appeared cool in the fridge, and that frozen bottle didn’t thaw out significantly in the time frame it was on DC and in the fridge, but when we saw the temp on the indoor/outdoor thermometer start to rise towards 50 degrees, we turned it back to propane where it ran fine and we could even decrease the level of the refrigerator temperature (ie - from 9 down to 6.) It was 90 degrees F outside yesterday, but I wouldn’t think that would be the proverbial “straw to break the camels back” so to speak… )
Therefore, my question is: Is this typical - or should it be doable to run this 3 way rv fridge on DC and have it work appropriately? (Prior to having the dc/dc charger installed, we had always run the fridge on propane when driving, but we’ve been taking heed of the reasons why it’s not the best idea and hence why we installed the dc/dc charger in addition to the solar panels. And, just to clarify, we had no issue with keeping the batteries charged with the dc/dc charger and solar panels when we had the fridge running on DC power- we only switched it over to propane because the temp was implying that it was getting too warm in the fridge.)
I’d love to hear others experiences regarding running their 2000 era AF fridge 3 way fridge off DC.
TIA!
  • That has been our experience, fridge will start to warm on extended run time on DC. Mostly due to the 12v heater is less wattage so less btu than gas or AC.
    Traveling generally hasn't been an issue once the DC charge is resolved, but will run warmer as the day progresses, especially as outside temps rise. But have never lost food due to temps, once stopped returning to gas or shore brings temps down.
  • Operation on DC will strain to keep it cold.
    Why not run it on propane like most RVers?
