- spoon059Explorer II
Bird Freak wrote:
Yea, I saw it too...
I wondered who the would be the first to take a shot at Ford in a Ram post. Anyone else notice not one low class shot taken at Ram? Stuff happens to all of them. Just an observation.:)
Some people can't help themselves sometimes. Other people can't ever help themselves... - Bird_FreakExplorer II
X2 on not driving. If it's the EGR cooler, it can cause more damage. If its the DPF if means its trying to burn off excess fuel, which could end up fouling it or plugging it with ash. A 2014 won't ever smoke during regen. Actually none of the 6.7's do, unlike the Ford 6.4L. - Turtle_n_PeepsExplorerFixed it, thanks Chris
- Me_AgainExplorer III
Turtle n Peeps wrote:
SoCalDesertRider wrote:
tdst51 wrote:
Yep, that is correct.
This is what I was told a long time ago. I'm not even close to being a mechanic, but here it is. Probably way more complicated than I realize.
1. White smoke- steam, or water related
2. Blue smoke- oil
3. Black smoke- gas/fuel
Not even close.
Look at these runaways running on oil.
I blew a turbo seal once and I never seen so much pretty white smoke in your life!
Here is a stuck injector
Blown head gasket
The only way I can tell these apart is the smell. Easy to tell if it's fuel, oil or coolant from the smell.
First two links are the same!!! Chris - Turtle_n_PeepsExplorer
2. Blue smoke- oil
Not even close.
Blown head gasket
The only way I can tell these apart is the smell. Easy to tell if it's fuel, oil or coolant from the smell. - jus2shyExplorer
2. Blue smoke- oil
In the case of diesels, white smoke can mean a rich diesel fuel mixture. For older diesels can happens when you have a very plugged air filter, for all diesels, can happen with a stuck fuel injector or just a cold start with incomplete combustion in some cases. - wnjjExplorer II
2. Blue smoke- oil
White smoke is also from unburnt diesel. The in-laws' farm 80's Freightliner (Cummins 350) cranks out a ton of it until it warms up. - fishhoggExplorerAre you making oil? (Oil level going up) Are you loosing coolant?
- SoCalDesertRid1Explorer II
2. Blue smoke- oil
3. Black smoke- gas/fuel - tdsxt51ExplorerThis is what I was told a long time ago. I'm not even close to being a mechanic, but here it is. Probably way more complicated than I realize.
2. Blue smoke- oil
