valhalla360
Sep 08, 2021Navigator
I wouldn't worry about aluminum siding. We've had both and I prefer aluminum. It's rare to find a fiberglass unit over 5yrs old without delamination. It's not unusual to find 20yr old aluminum trailers where it may look dated but otherwise in perfect condition.
Probably the biggest concern I see with the Wolf Pup is it only has 780lb of cargo capacity. 80lb of propane, 60lb battery and 200lb of water...and you've eaten up 50% of your capacity...For a family of 4 staying under 1200-1500lb takes effort. That means you are will be tempted to put more gear in the truck and overload the truck.
Check the payload sticker on the door (or better swing by a CAT scale and find the real weights and check vs the truck GVWR)...I did a quick online search and 13XXlb payload seems to by typical.
- 4 people at 150lb = 600lb (the kids will grow)
- Hitch weight should be up around 600lb
- Hitch might weigh 100lb
- That's it, don't pack a cooler or anything else in the truck or you are over weight.
