toedtoes
Sep 08, 2021Explorer III
Max-4 wrote:
So are we saying that I will struggle with a V6 Toyota Highlander with 5000 pounds towing capacity pulling a 3900 pound gross weight 21' travel trailer? I'm not talking dry weight, most of the trailers I quoted above are under 4000 pounds gross weight. Thanks
It may or may not be. You need to determine payload needs and limits for the vehicle, cargo capacity and needs for the trailers (some trailers will use up the cargo capacity just by filling the fresh water tank), road types and terrain, distance, and so on.
You have to look at more than just those two numbers (gvwr and tow capacity) to determine if it will work.
In addition, with four kids in the car, you may not feel comfortable towing something that "pushes" you down a grade. So that may mean going lighter than you are estimating.
You might see about renting or borrowing a trailer of similar weight and size and see how it feels to tow it before making a decision.
