valhalla360
Sep 09, 2021Navigator
Max-4 wrote:capacitor wrote:
Does the Highlander have a receiver and 7way plug? Seems like a pop up trailer would be better to start with. Your mirrors will work without replacing them. What size v6, 3 liter? It’s built on the Camry platform.
My 2017 Toyota Highlander AWD has a 3.5L V6 and makes 295hp and 263 lb-ft of torque. It has a max tow rating of 5000 pounds and I do have a proper hitch installed but I will have to upgrade from a 4 way to a 7 way plug and get a trailer brake controller installed, not a problem.
You have plenty of HP, though it likely will be running at higher RPM than you may be used to.
While there is no issue running at 100% of the ratings (the engineers aren't going to recommend unsafe operation), there is more than one rating to consider, Tow Rating is mostly about HP and braking. Payload is where you are likely to run into problems.
