Grit_dog
Sep 09, 2021Trailblazer
Max-4 wrote:
So are we saying that I will struggle with a V6 Toyota Highlander with 5000 pounds towing capacity pulling a 3900 pound gross weight 21' travel trailer? I'm not talking dry weight, most of the trailers I quoted above are under 4000 pounds gross weight. Thanks
The term struggle is relative.
Hard to explain to folks who aren’t already kinda saavy with vechiles and trailers, but in general, mid size uni body suv cuv type vechiles aren’t stellar at towing.
Just like pickup trucks aren’t stellar at things Cuvs or sports cars are.
Safety is also relative and not only related to the vehicles abilities but also the drivers experience.
You appear to be on the lower end of both which is what gives some people pause.
That said, there is nothing in your proposed setup is inherently mis matched.
Just know you’re on the upper end of the limits of a vehicle that’s only marginally designed for towing and hauling.
If you’re planning on x country trips, mountains, high altitude etc I would not say the Highlander is well suited at all.
That said, just keeper rubber side down and you’ll be good!
