handye9
Mar 22, 2020Explorer II
As you've noticed, you don't want to base your trailer search on that mythical "max tow weight" rating. Here's a list of various pieces of information that will help in your search.
1. Max tow weight ratings are calculated without passengers or cargo. That's not how we go camping. As you fill your truck with people, pets, and cargo, it's true towing capacity is going down.
2. There's a tire / loading sticker (on your drivers door jamb) that shows your particular trucks capacity to carry everything / everybody you put in it or on it. That number is listed as "max occupant / cargo weight" (AKA payload). Depending on installed options, cab size, power train, drive train, suspension, axles, tires, etc, every truck has it's own payload number. Not all F150's, F250's, Ram 1500's, Ram 2500's, GM 15 and 2500 series, etc are created equal.
3. The weight of added hitch / anti sway equipment and tongue weight from a trailer are counted as cargo weight on the truck.
4. Trailer tongue weight is NOT a constant number. It fluctuates with loading and usage during every trip. Average is 12 - 13 percent of loaded trailer weight, however, it can be higher at times. You never want your tongue weight lower than 10 percent.
5. Trailer sales people talk unloaded and gross weights on the units they sell. Neither of which is likely to be what you'll be towing. The trailer will be heavier than unloaded weight, before it gets off the dealers lot, and it's very rare for an average camper to load up to the gross weight on the trailer. Average loaded trailer weight is 800 - 1000 lbs higher than it's unloaded weight.
6. Take your payload number and subtract weight of your family, weight of your cargo, weight of aftermarket accessories (if any) added to the truck, and 100 lbs for hitch equipment. Whatever is left over is payload available to carry trailer tongue weight. If you divide that available payload by .13, that will give you a ball park figure of what "loaded" trailer weight will put your truck at or near it's max weight. That loaded trailer weight could be considerably lower than your "max tow weight" rating.
Note: Closer you get to max weight or over weight, the more unstable / unpleasant you towing will be. Give yourself some cushion.
44,059 PostsLatest Activity: Mar 18, 2026
