modern_family
Sep 23, 2013Explorer
From the factory, the bearings are packed just as you would a regular set of bearings with grease just inside the bearing itself and that is all. The hub is completely empty and as stated above, you will use atleast a tube of grease to "fill" the hub before it pushes the original grease out. Most will agree not to use the EZ lube to avoid damaging the seals and wasting grease and just re-pack once a year or so depending on mileage.
44,068 PostsLatest Activity: Jun 17, 2026
