69_Avion
Sep 23, 2013Explorer
You have to rotate the hub to get the grease to go around the bearings. If you don't rotate the hub you can blow the double lip seal. If you have pumped a lot of grease, and you don't see any coming out the front, then it is time to pull the hub. It isn't that big of a deal, but you will need a new seal and make sure you set the nut (bearing tension) properly. You don't want it too tight or too loose.
Besides, it is good to check the brakes while you are in there.
44,068 PostsLatest Activity: Jun 17, 2026
