schlep1967
Sep 06, 2017Nomad
First thing to figure out. Is the water coming from outside, is it a plumbing leak or a shower stall leak. Simple way to figure out if it is a plumbing leak is to have some water in your onboard tank and turn on your pump. It should run for a few seconds until it pressurises and then shut off. Sit in the trailer for a half hour, look at your phone or whatever. If the pump cycles back on you have a plumbing leak. If not and you do not shower in the trailer you know it is coming from outside. If you do use the shower turn it on and look for water leaks around the shower.
44,055 PostsLatest Activity: Dec 23, 2025
