Artum_Snowbird
May 28, 2018Explorer
I think you mean a soft spot on the floor.
Looking at your floor plan, you have a toilet to the right. That might have a leaky floor connector. You have a pop out and that is the access to the bed. Water might be coming down from a leak off the roof to wall connector, or around the seal from the pop out.
I would consider cutting out that section of lino back to the bathroom door, seeing if you can fix it after that, and replace it with a few pieces of wood grain flooring and a strip of connector.
