raztec
Jul 07, 2013Explorer II
Help fixing wood rot
Perhaps there's a post on this but I did a quick search and came up empty.
I've got a pop-up Palomino Bronco that I just discovered has wood rot on the very front panel pop-up portion. I want to fix it properly then reseal it and need some help as I've never done this before. A few questions:
1. How much more than the rotten portions do I need to remove?
2. What kind of wood should I replace it with - simple plywood?
3. Do I need to apply any special sealant to the underside?
4. What's the best sealant to use on the outside surface?
5. Am I better off giving this to a pro to avoid this happening ever again, or is this an easy DIY weekend project?
Thanks
R
Thanks
R
