kaydeejay
May 29, 2013Explorer
skipnchar wrote:What Skip says - the 3500# max tow rating is with a 150# driver in the van and nothing else.
3500 lb. minus the weight of passengers and cargo carried in the mini van gives you the maximum trailer weight. A more accurate way would be to weigh everything fully loaded and make sure it's less than the GCVWR of your van.
Your 3500# is reduced by anything over that 150#.
The other number you need to watch is payload. Add all the occupants and cargo to the tongue weight of the trailer and make sure you are under the payload rating as well as the max tow rating.
44,066 PostsLatest Activity: Jul 25, 2018
