ADK Camper wrote:
I want a generator mainly to charge my battery while perhaps using a couple of lights and intermittently using the water pump. I don't expect it to power any "heavy hitters" like the micorwave, water heater, or AC.
Would the Honda EU100i be sufficient for this? I know the EU2000i would do the job, but I'd like to go with the lighter, cheaper EU1000i if it will get the job done.
I'de appreciate opinions from anyone using either of these models, especially if you use the EU1000i.
A Honda 1000 will probably not run your microwave depending on how large a unit you have.
I have a Honda 2000i and use it for charging my batteries using a 40 amp battery charger. Using the Honda to directly charge your batteries is a long process when a good battery charger is so cheap.
My 2000i will run my Coleman A/C on my Wolf Creek
