donn0128
Sep 11, 2013Explorer II
Start by loading everything up in it you would normally have when traveling including family and drive to the scales. Subtract the scaled weight from the GVWR listed on the drivers door post. THAT is your net cargo carrying capacity. That 3422 number is the difference between a base trim level truck with the smallest gas motor and the GVWR. As you add stuff you also have to subtract weight.
44,071 PostsLatest Activity: Aug 30, 2026
