bg71361
Jun 13, 2016Explorer
I can see the clear plastic pointer pointing to the tank on the right, appears to be an auto switch over valve, so with both tank valves in the open position and the pointer pointing right it will pull only from that tank UNTIL it is empty at which point it will automatically draw from the open tank on the left.
Hope that makes sense!
Good luck
Good luck
44,067 PostsLatest Activity: Jun 05, 2026
