Kayteg1
Jun 14, 2016Explorer II
I found all those switch over valves leaking internally.
Meaning if you pull the empty cylinder for refilling, the propane from the other cylinder will leak out via disconnected fitting.
Since I like to do that and still have propane in the camper, I disconnected one of the short hoses and cap the fitting.
This way I can use camper with single cylinder and I know precisely when one is empty.
44,069 PostsLatest Activity: May 08, 2013
