mosseater
May 24, 2023Explorer II
We've had our Sunset Creek by Sunnybrook since 2007 and as far as an "Indiana" product, it's held up remarkably well with minimal maintenance. As J Barca said, concentrate on base construction because as far as I know, most everything on any trailer is a purchased component which each manufacturer specs for their particular trailer. Lippert and Dexter are two major players. I-beam frame rails instead of welded H-beam, axles, brakes, tongue jacks, slide out mechanisms, etc., used to be vendor supplied. Not sure these days. IDK if any of them went proprietary on all components or not.
Sunnybrook used to be a very good trailer before Winnebago bought them out. We bought ours during the take over period and it was claimed long time employees were jumping ship. Sunnybrook had the most long term employee base of most of the manufacturers in Indiana at the time. I would loosely claim "craftsmanship" may have been higher than most, but their stock in trade was not changing designs much over over time. Sort of the bread and butter of trailers without a lot of frills. I admit I don't keep up with it, but early examples of smooth sided trailers (Filon) were abysmal in use. Saw some horror stories unfold on this board many times. I prefer the look and relative ease of repair of stick and tin over "fiberglass" smoothies. Opinions vary. You takes your chances and spin the wheel when you buy one. That much is clear. And yes, get used to doing repairs... or have deep pockets for your local Rv store to do them for you. You WILL likely need to do things yourself.
