westend
May 31, 2013Explorer
Obviously, the material used for the floor isn't the problem.
Since it is close to your water supply lines, has anyone tested them under pressure to see if there is a leak. Also, you live close to the coast so condensation issues might develop. If the area pictured is in an exterior corner, I would expect water intrusion from the outside is the cause.
Also, it appears the repair of the floor was not continued under the wall. If the original rotting floor was left in place, it may continue to rot.
