westend
Apr 06, 2014Explorer
It looks like you can cut the black pipe inboard of the siding wall. You should be able to slide a new piece of pipe onto a repair coupling, inboard, and then attach the final drain coupling to the exposed new pipe. All of this can be done without removing the red siding piece.
I don't understand why the drain hose connector is 5" out from the wall. It could be flush or nearly so and that would prevent just the kind of thing that happened.
44,030 PostsLatest Activity: Jan 21, 2025
