KD4UPL
May 19, 2014Explorer II
I have no idea what a "ground buster" is and I'm a licensed electrical contractor. Codes change and wiring schemes are different. This same thing got drawn out forever a few months back.
Without getting into all the various code reasons and wiring scenarios it may or may not be correct for the grounds and neutrals to be bonded together in your garage panel. Either way, you can certainly hook up an RV outlet. You would put both the ground and neutral from the RV outlet onto the bar.
44,066 PostsLatest Activity: May 15, 2026
