wrigley615's avatar
wrigley615
Help please! I'm locked out
Hi everyone. I'm leaving in a few days for a 9 day trip and all of a sudden I can't get my key to open my travel trailer. I have probably what most of you all have, it's a FIC door latch with a deadbolt lock and the normal lock. The deadbolt works just fine but the other lock doesn't let the key go all the way in. I was able to break in through the storage area in the bunkhouse and I can't get it to unlock from the inside either. There is nothing stuck in the keyhole from what I can tell and I used the liquid graphite also to lube the keyhole. I've also spoke to a service guy from camping world and another service guy from a local trailer supply place and they had nothing. I've put in a call to FIC but it only goes to voicemail. Next I'll call Forest River but after that I'm stuck with calling a locksmith and that will cost a couple hundred I'll bet. Oh yeah, I also called Geico roadside assistance and they told me if it's the key it's covered but not if it's the mechanism it goes into. Plus being that my RV is at it's storage facility then it's not an emergency so no luck there. Any ideas are appreciated cause I'm out of ideas.
  • When it happened to me, I tapped my key in with a rubber hammer and was then able to un-lock the door and replace the unit. Good luck.
