Samsonsworld
Oct 19, 2015Explorer
Of those you mentioned, a properly equipped F150 would be best suited to the task. You won't find a better gasoline tow engine than the 3.5l EB. Personally, I think 1600lb payload would likely be adequate for that trailer, plus any weight you plan to put in the bed. You'll also want good tires. 40psi won't cut it. I would say 50psi minimum. E-rated with 80 psi would be best. My $.02.
