Tyandkate's avatar
Tyandkate
Help! Shower leaking
I had a hunch to look under my bath/shower unit in the jayco today (waiting on the missus to finish her make up) and noticed water under the shower... I did have to re seal around the tub a few months ago and thought the problem was resolved. It appears the leaks are coming around the top half of the unit. There are little anchors going through The walls. And around the top. When I get home I plan on pulling the unit and accessing the damage. My question is has anyone else had this problem? And if so what are the solutions. Thanks
  • Check all the fittings behind the shower access panel. When we took delivery with new Jayco last august noticed little puddle next to toilet and a fitting was loose near back of toilet. Proceeded to check all the water supply fittings in the camper and under the shower fitting was not tight either. It was a slow drip. Under the kitchen sink fittings I tightened also.
