nohurry's avatar
nohurry
Help solving tire wear pattern please
This is the left rear tire on our TT. As you can see, the inside edge has been wearing down. It is time soon to replace the tires per mfr date, but I just noticed this and don't want to wear out a new one prematurely. The other three are fine. Can any one here tell me what condition could cause this? I check PSI before every trip. Is there a way to adjust the alignment? It has the mor-ride mounts on the springs as well. Also the bearings were cleaned, and re packed last spring, and the tire doesn't seem to be loose on the spindle. That's as much info as I can think of. Thanks in advance for any ideas you may have.
On edit, they're Goodyear Marathons.
