kooka7
Jul 24, 2014Explorer
Help us choose a TT (5 kids + 2 adlts)! TV - 07 Expy Ltd
Hi All,
I hope you are well. (Apologies for the long post, i've included as much info I could think of)...
Hubby and I are at the stage now of exhausting appropriately sized TTs for the family. We have 5 kids, with out eldest 7yrs, then 6 yrs, then 4 yrs, then 3 yrs, then 15 months...
Our TV would be a 2007 Ford Expedition Ltd version, fully loaded if that means anything as far as weight goes?.
I have provided as many specs as I could find in relation to weights etc.... and would dearly love someone to translate for me what is the maximum weight we are able to tow with the expedition. I am slowly coming up-to speed with the lingo but its still all goblidook to me!
In all honesty, I think we may be pushing it with the larger bunkhouse type models but there were a few that we had pinpointed that would suit our needs with a growing family. The main criteria is fitting 5 kids in the rear bunkhouse and hubby is keen on an outdoor kitchen!
There are not alot of RV's so far I have come across that have outdoor kitchens without compromising bunkhouse beds, those that do tend to compromise on a bed in the bunkhouse and some of the quad bunks are out for us as there is no where for no 5 to go...
So the specs on the expy are as follows:
Manufacturers sticker on rear drivers door
GVWR:7700LB / 3493kg
Front GAWR - 1610kg
PNBE AV - 3550lb
REAR GAWR - 1928KG
PNBE AR - 4250LB
TYRE SIZE 275X 55R20
RIMS - 20X8.5
(YELLOW STICKER) TIRE AND LOADING INFORMATION
The combined weight of occupants and cargo should never exceed 701kg/1547lbs.
CLASS IV HITCH
MAX GROSS TRLR WT (LB) 9200
MAX TONGUE WT (LB) 920
MAX GROSS TRLR WT (LB) - WEIGHT CARRYING - 6000
MAX TONGUE WT (LB) - WEIGHT CARRYING 600
I have TWO trailer plugs. I have the option of EITHER a 4 pin rectangular plug, OR, a round plug.
Q/ is the round plug referred to as 7 pin? it has 7 prongs as such??
In the drivers side along the rhs bottom underdash area (where your knee kinda is) I have a small black "BRAKEMAN COMPACT" installed with "REESE" branding. This works, as we have already hooked up a standard U haul type trailer.
I know there are a few questions, but some clarification on tow weight would be super appreciated from those who have the calculations down pat!
As for the models we were looking at, we narrowed things so far down to this type of configuration (again because there is no compromise on having 5 kids at the rear of a bunkhouse):
* 2013 COACHMEN FREEDOM EXPRESS 312BHDS RV
* 2015 Jayco EAGLE 314TSBH
* Keystone 3220BHWE
I know that we also need to factor in the weight of occupants, gear, food etc also....
We would also need to get one of those anti-sway hitch type bars installed. Not sure what brands there are - any suggestions pls?
If there are some folk who could help us out with what we can tow weight wise on the expy we can then be in a better position to determine where we stand and exhaust other options if need to on the TV...
I'm still researching manufacturers and what finishes exterior are suited to the weather in calgary as we would still like to utilise the TT in Autumn as well as the warmer months....
Many thanks for your help,
Cheers,
K7
Front GAWR - 1610kg
PNBE AV - 3550lb
REAR GAWR - 1928KG
PNBE AR - 4250LB
RIMS - 20X8.5
CLASS IV HITCH
* Keystone 3220BHWE
Cheers,
K7
