Foodi wrote:
I think it would be the C.O.G to be the biggest drawback and the truck may not handle well? This camper is on a F250 LB with current owner, so I hoped an F350 would make up for the shorter box size.
Absolutely not. It’s a common misconception that an F350 (single rear wheel) is any different than an F250.
It’s the same truck, with slightly stiffer springs which you can add to an F250.
Lots of RV guys say nothing you do to a truck increases its payload, you have to just buy one with a higher rating, because they believe if the factory adds a spring, the payload goes up, if you add the same spring, it doesn’t.
About truck selection, I believe it’s silly to buy a shortbed with the main purpose being camper hauling. A shortbed turns a little tighter. A long bed is superior in every other way.
