ncwelder88 wrote:
i have a bunch of questions but will stick mainly to the important ones for now, so here we go and please ignore any ignorance as i know nothing about tt's.
1. should i replace the vent and fix all the paneling or patch the vent and seal it???
>>Try the patch for now...don't dig in too far yet.
2. where can i find the main breaker box for the electrical??? i found the fuse box access panel on the outside near the tongue of the trailer!
>>Usually the 120V breakers are near the 12V fuses. Also, look near where the power chord enters the TT...probably at the rear on the drivers side. determine if the power receptacles favor a side or front or rear...seems I saw an outlet near the door. The builders will use the shortest length of wire and will try to provide plugs and the 120V breaker close together. Understand there is 120V going into the tt, but once inside an invertor will convert some power to 12V which will power lights, refer, powered vents, etc.
3. in attempt to get on the roof i noticed that the roof was awful wavy and decided not to get up on it. does the roof need to be replaced? and if so are there any tutorials or writeups on replacing one of these roofs
>>Is the roof metal or rubber? Roof attention really can't be commented on. You'll find info, just start searching. Maybe not this exact TT.
4. does anybody know part numbers to put newer brakes and hubs on the fayette-dayton axles?
>>I'd replace the entire axle ass'y...brakes, bearings and all.
5. andd last question (for now) can anyone give me any information on this camper? i have found that alot of the older terry and taurus campers look almost identical.
>>Most models really don't change except for decor...upholstery pattern, exterior stripes, floorplans. Do you have a title? any paper work that could tie down the year? Models that look similar will probably be a help to get to know yours.
I agree with what has been said earlier. Get some quotes on parts, search and plan before you start. You've got sweat in it already, but how much more does it need? These days tt are built pretty good, but they have a life and early ones aren't what you get now.
