time2roll
Jun 07, 2020Nomad
Remove the lower trim and inspect the evaporator for ice. If it has a wall thermostat look for the freeze sensor and get it placed in the ice. Also check the plenum divider is placed correctly and sealed to properly separate the air-in vs air-out.
You can cycle it yourself to clear the ice by leaving fan on high and cycling the compressor off. Or alternate the air units every 30 to 60 minutes.
44,065 PostsLatest Activity: Apr 14, 2026
