CavemanCharlie
Jun 08, 2020Explorer III
ford truck guy wrote:
My brother in law swapped his 13.5 A/C last year for a brand new 15k A/C at a local RV repair. That place is now closed and he had an issue this past weekend..
We were camping in 90* weather Friday and Saturday with NO Issues... a front came through last night and took the humidity and heat away with temps in the 70*'s this AM.. He had cool air blowing, but it was not blowing hard... went up on the roof and his lines inside the shroud were all frozen...
He is 50 amp with 2 A/C's and was plugged into 30 amp service so was only using 1 AC..
Any ideas on what may be happening...
If the change in air temperature and humidity were quick then it's possible that it just couldn't keep up with the sudden change. Don't worry about it unless it happens to often.
It's hard for these systems to change quickly. Give it a chance. It may never happen again. Or, it may happen only in a situation where temps change quickly.
Shut it off, let it defrost, and try it again.
44,066 PostsLatest Activity: Jul 25, 2018
