Snomas
Jun 11, 2020Explorer
My front AC would freeze up if I had the temp set too low when it was 90* plus outside and if I had the temp set on 72-74 degrees. I was told by a HVAC repair man that I should run them at 78 or higher and they wouldn't freeze up. This was on my 02 Dutch Star with 2-13500 units. Later in life I changed them out to 15000 units and never had a freeze with temps set at 74 degrees and over 108 outside. My DW never wanted to use the DS in temps over 100 until I got the 15K units.
Not sure why this little TT I bought last year will do in hot climates w/ only one 13500 init
44,066 PostsLatest Activity: Jul 25, 2018
