budwich
Jul 18, 2016Explorer
you likely aren't going to get away without taking out the foam. Actually, the foams integrity is likely been compromise by the moisture anyways. You best best is to replace the foam with sheet "foam" insulation using in building / homes.
44,056 PostsLatest Activity: Dec 27, 2025
