conant47f wrote:
Well the way it sounds it's the gas valve. Can I even get parts for this anymore? Will any other parts switch out if not? Again thanks for everyone's help. You have helped me a ton!
First see if you can get the main burner going.
Report back if you do or do not. I am guessing that once the main burner is on for a few minutes anything that might be blocking the pilot light tube.
You should be able to get a replacement but you will need the model and serial number.
Get the main burner on if it will light
