srschang wrote:
Sleepy, 2.5 LP Onan $2772 on Amazon
Model Number 2.5HGJBB-1121A
Manufacturer Onan
Made In USA Yes
Rated Watts 2500
Rated Amps 20.8
Voltage 120V Single Phase
AC Ton Rating Up to 13,500 Btu AC
Decibel Rating 7m 70 dB(A) @ 10 ft. half load
Features
Starting System Electric Start
Low Oil Alert Yes
Mainline Breaker 25 Amps
Hour Meter No
Weight 125 lbs
Dimensions 22L x 16.3W x 12.8H
Engine
Engine Brand EX21
Engine RPM 3600 RPM
Cooling System Air Cooled
Alternator
Alternator Type Brushed
Frequency 60 Hz
Auto Voltage Regulation Yes
Fuel
Type Propane (LP)
Gas Tank Size Customer Supplied
Run Time 0.4 gal/hr (1.6 lb/hr)
WOW! And thank you.
And you were able to replace a Generac LP generator with it
Is it a tight fit on the long axis. (22”)
I’ll have to check my heigth and depth
Does it handle our 13,500 Air Conditioners easily? That is 95% of my need for a generator.
And the other 5% is our microwave. I can turn off the AC long enough to microwave a couple of Lean Cuisines
Chet
