riven1950's avatar
riven1950
Help with how to operate my HWH
We have a 2014 Apex by Coachmen. The HWH is a Suburban SW6DE
We used it for a month or so last winter and all was ok, still is as far as I know. Just can't figure out the switch positions. We are preparing to leave for a trip this week and are checking things out.
I decided to try it on gas. We thought we had been using it on Electric in the past but now I am confused.
The manual says to operate on electric turn the little black switch on in the outside compartment. It has been on all the time. We have been turning on the wall switch inside when we need hot water and it has worked. Today when I turned the wall switch on the gas burner lit, which is good I guess cause the water was hot quickly, but the way I read the manual it should be on electric with switch in that position.
I am trying to figure out how to operate on just electric or just gas and what position to place the switches for this?
I hope this makes sense. We have been careful to not turn it on without water in it.
Thanks
    I'll have to make a few educated guesses.
    Your WH can work on both elec and gas at the same time. If the water was hot 'quickly', it may have been hot already from electric (assuming you're on shore now). A wall switch is normally for gas. If you want just gas, turn off the switch outside on the wh itself.
