jriggs10's avatar
jriggs10
Help with my new (to me) Caribou
Hey there helpful camper crew! We went on our first camping trip last weekend and I had a couple of questions about our '98 Caribou camper.
Hot water heater- The pilot light fires up but no hot water, not sure if there is a valve that I didn't turn on to get hot water to the tank maybe?
Refrigerator- I had it on gas, and when we were travelling, it turned off, is there a different way to travel and keep it on? It looks like it runs on gas or 12v (I am assuming that means the electricity when it is plugged in?)
Gas forced air heater- When I got the camper, the fuse for the heater was blown, I replaced it and turned on the thermostat and nothing happened... I thought there would be a place to light the pilot light, but there is nothing on the outside of the camper or where the grate comes off.
Storage- There are four storage compartments that go into the bed of the truck. Best idea of things to store in there? Also, Not sure where to store fishing poles/shovels/etc.
Thanks again all for your help!!
Jeff and family
  • Thanks Steve,
    I left it on for a long time, but nothing is happening, not clicking, no fan, no blown fuse, it almost feels like there is some switch I am not turning on so gas is getting there. There is an on/off switch to the thermostat and it is on, and turn the lever up over 90 (inside temp is around 70) and still nothing! Any more ideas?
    Also found out it is a hydro flame model #7920
  • Fridge - I used to run my old absorption fridge on 12v when driving, but it draws a lot of current. However, you wouldn't want to accidentally leave it on 12v when you get to camp. My absorption fridge was an old style one with no electronics - if you left the fridge on 12v it would empty your battery until not a drop of electricity was left in it and you would be in the market for a new battery the next day.
    Heater - Did you leave it more than a few seconds? On my heater I switch it on with the little switch on the bottom of the thermostat, then set the thermostat (hot enough to turn on), but it takes maybe 20 seconds before the unit responds and the fan starts up. Then it is a number of seconds before the ignitor fires up, and finally it is 30 seconds or more before you notice the air coming out noticeably warm.
    Steve.
  • JumboJet wrote:
    First thing that comes to mind - Blower Motor not turning. I have the same situation on a motor home. When I switch the thermostat to heat, it immediately blows a fuse. I have to remove it to check it out.
    There are not very many components to the heater. Blower motor, gas valve, ignition device, control board, and sail switch. If the blower motor is not turning, I would check that first. The thermocouple tells the control board that the burner is ignited. The sail switch tells the control board that air is moving through the heater.
    When all these are working correctly you have heat.
    Jeff and family
    I switched it to heat but nothing happened, no blown fuse, no click to indicate that it would turn on the heater, nothing...How would I know if the blower motor is bad? Also, you are saying it doesn't need to be lit? Thanks!
  • ~DJ~ wrote:
    I'll give this a shot but it's worth as much as you paid!!
    You may have a water heater bypass for winterization. It is a hose that usually runs along side the tank with 3 valves. One at the top, middle and bottom. Try reversing each valve from it's present position. The top and bottom valve should both be in the same position opposite the middle. If your tank is empty the WH will not heat. Hope this makes sense!!
    I also had one that the wind, while travelling, would blow out. I just left if off until I reached my destination for the night and re lit. If you run it for a couple days before you leave and get things good and cold should be no problem. The 12 volt is for running it off your camper battery which is a bad idea. Takes more juice than is put in and runs battery dead in an hour.
    Can't help on this one.
    Pretty much anything that will fit. Good place for small gas cans or the little bottles of propane. I carry a short shovel in there.
    Jeff and family
    So if I want to keep the fridge going is it ok to switch it to electric while I am traveling because the truck motor is charging the battery?
    Jeff and family
    Jeff and family
