MFL
Sep 13, 2015Nomad II
deltabravo wrote:
The spindle doesn't appear to be centered in the hub (brake drum), and if that's truly the case, then it needs bearings too, because something has come loose.
I'd start by jacking up that side of trailer so the affected wheel/tire is off the ground. Grab the tire with one hand on each side and see if it wobbles back and forth.
It honestly looks like there's a problem other than just a missing dust cap and rubber cover.
This was my thought too. Pictures can be deceiving, but the nut appears, not to be centered.
Agree with raising to check wobble.
Jerry
