Gdetrailer
Sep 13, 2015Explorer III
Remove the wheel, it will make the job a lot easier.
I will second another post, you have a bearing that has blown, that is the reason the cap is gone.
You will need to remove the wheel anyways to remove the hub, inspect, clean and most likely replace the bearings.
Looks to me like the castle nut, washer have rust on them.. That is a sign that moisture has been present.
