Huntindog
Sep 13, 2015Explorer
Godspeed999 wrote:Whoever did the bearing repack did it wrong. It looks to me like the spindle had been damaged by the bearing , which appears to have parts of it's cage where it should NOT be.. You may need a new axle when all is said and done, and you for sure need to have all of the bearings inspected by a competent mechanic.
Thanks for the subsequent replies while I was typing my response. I agree that the nut looks a bit off center. I had new bearings installed last fall but that doesn't mean it couldn't have failed.
Now is not the time to pinch pennies. It will just end up costing more in the long run
