fairfaxjim
Sep 27, 2015Explorer
CKNSLS wrote:
You can do what makes you comfortable. IMHO servicing the bearings annually is not needed, and for those who can't DIY it would be expensive-and again unneeded. The annual inspection and replacement of seals at 12,000 miles is a CYA that is published by the manufacturers. BTW-these very points I have made and you have mentioned as well have been beat to death on this board. One easy way to see if you have "functional brakes" is to pull the lever on your brake controller before one takes to the road. Something that should be done anyway to make sure you brakes are operating properly anyway each and every time.
Like you said, whatever makes you comfortable. I'm totally comfortable with knowing that when I head out I will make it back. YMMV
